PanelProps dataframe doesn't show duplicated entries
I was looking at the SimplePanel code and I was hoping you could help me. I modified the code to have the following:
interface Props extends PanelProps {}
export const SimplePanel: React.FC = ({ options, data, width, height }) => {
return
{data.series[0].length}
I noticed that it doesn’t show the duplicates, for instance if I use:
select 1 union select 1 union select 1
it reports length 1 but it works fine when the numbers are different.
Do I need to use or create a different PanelProps or am I doing something wrong?
Thanks,
Jorge
I’m not sure what you mean by “duplicates” or “select 1 union select 1 union select 1”.
Could you give an example maybe?
That was my mistake, I wanted to show all numbers in the query (1,1,1) without adding any other field so they are different.
