Hello!
would like to ask, that the Labels are not transformed. It should be 8000mA not 8A
THX
By default units are always converted based on magnitude. To override this, you can click on the “Unit” dropdown and manually type in “mA”, to enter that as a custom unit. This way your raw numbers will simply be prefixed with “mA”.
Thanks, what I did not recognice is, that inside the popup you can scroll down, there is the custom unit situated.
