Override - Time: custom unit from variable
Hi, I am unable to configure custom unit for the time axis from a variable (Overrides > Standard options > Unit).
When I type “time:DD.MM” (without variable), everything is OK.
When I type “time:$unit” ($unit = “DD.MM.”), then I see “$unit” on the time axis.
When I type “$unit” ($unit = “time:DD.MM.”), it has no effect.
Does anybody know where problem is?
Thanks
