Grafana v7.1.1 (3039f9c3bd) on macOS Catalina v10.15.7 (19H1323) -
Use OverOps dashboard within the week or more without being needed to re-login and re-select all dropdown fields on every new day (seems 24-hour session expiry…) -
Open existing OverOps dashboard:
OverOps - Login -
What happened?
[GIF is attached] OverOps dashboards opened in browser (Chrome, latest) tabs are expired and can’t be refreshed (inbuilt refresh and browsers refresh buttons). -
If I refresh OverOps dashboard (in-built refresh button in dashboard (top right corner) or browser refresh), no re-logining and re-setting up dropdown fields are required. -
NA -
NA -
NA - I was asked to post request here by Grafana team
