Would have been great if this was a feature.
please upvote or like if you agree
Hey @yosiasz,
just curious…but isn’t this already possible with the transformation Filter by Name?
You can write any regex pattern to filter and thus only include the columns you want based on their names. This is assuming the column names won’t change and all this fits your use-case scenario.
Only difference with “Organize Fields” is that you have to write a regex pattern instead of being able to click the columns…and that “Organize fields” is indeed based on exclude whereas the regex field in “Filter by Name” is based on include.
