Order Stat panel by CPU usage
Hi all,
I use for CPU usage Polystat panel wich have a nice functionnality: order servers by CPU usage (for example).
But with last update (8.0.3), I have some issue with Polystat panel, so I switched to Stat panel.
However, I didn’t find the way to order by CPU usage all my servers (one request by server on CPU usage).
I searched on transform, but didn’t find anything helpful.
Is there a way to do it ?
Thx :slight_smile:
Hi @eglyn
Can you share you panel json so we can try and help you better?
