Oracle $__timeFilter replaced by macro is not working
Hello All,
It seems the __timeFilter macro is adding extra quotes("") for the date/time field, which is causing the query to fail on oracle. When I Just removed the quotes the generated query runs fine on the DB.
Query Generated with error ORA-00904: “Time”: invalid identifier*
  • select Time as time , values as value from SPLUNK_Redemp where “Time” BETWEEN TO_DATE(‘19700101’,‘yyyymmdd’) + (1/24/60/60/1000) * 1564509947046 AND TO_DATE(‘19700101’,‘yyyymmdd’) + (1/24/60/60/1000) * 1567101947046 order by time asc
Oracle doesn’t like it, so if i change the query to below, then it works.
select Time as time , values as value from SPLUNK_Redemp where Time BETWEEN TO_DATE(‘19700101’,‘yyyymmdd’) + (1/24/60/60/1000) * 1564509947046 AND TO_DATE(‘19700101’,‘yyyymmdd’) + (1/24/60/60/1000) * 1567101947046 order by time asc
Is there any way we can avoid macro adding the additional quotes to the time field?
Thanks.
are you able to use any of the macro yet as i am still not able to work with those.
