I am wondering what is the best way to implement an operative dashboard that will show like a heatmap of all apps under the company.
The dashboard should show the status of every app and have a drilldown to its components that will be a heatmap as well to see which one made the alert or the warning.
We currently implemented it using ‘Status by Group’ panel and it is working fine, but the panel is really disconnected from its parent and child (drilldown), so we need to ensemble all the metrics and threshold in each of them, and when we add a component we need to add it for the all hierarchy.
Is there a better solution or a best practice ?
