Opentsdb enable histogram in grafana
    8.0.3
    I am trying to run the following query using an opentsdb datasource:
curl -k --request POST
–url http://opentsdb-read.cdl.internal.pan.run:4242/api/query?details
–header ‘accept: application/json’
–header ‘content-type: application/json’
–data ‘{
“start”: 1626883258000,
“end”: 1626886858000,
“queries”: [{
“metric”: “forwarding_logs_latency”,
“aggregator”: “sum”,
“showHistogramBuckets”: true,
“percentiles”: [50.0],
“downsample”: “15m-sum”,
“histogramQuery”: true,
“tags”: {
“schema” : “*”
I am trying to implement the same query on Grafana.
  • What happened?
No data is returned.
I wanted data to show up.
    My original query is above. This is the query grafana uses:
request:Object
method:“POST”
url:“api/datasources/proxy/23/api/query”
data:Object
start:1627285851341
queries:Array[1]
0:Object
metric:“forwarding_logs_latency”
aggregator:“sum”
downsample:“30m-sum”
tags:Object
Notice there is showHistogramBuckets or histogramQuery field in the query. Is there a way to embed showHistogramBuckets and histogramQuery inside the query?
No
No
