OPC UA Dinamically change instance with variable
    Grafana v9.4.7 (4add91f03d)
    Windows 10
    Plugin: OPC UA (Unified Architecture)
    Change dinamically Instance on UA Node Selection from a variable
    for example change dynamically instance like:
    This: AllenBradley/dcalle22/online/B3:0_1
    To this: AllenBradley/$alias/online/B3:0_1
    Creating a Variable called alias
    Then i try to insert it in Instance under UA Node Selection
  • What happened?
    I get a error that say Failed to call resource
    04
    To be able to change dinamically readings of OPC UA with the combo box created through the variable
    05
Thanks for your help
