OnVariableChange Event :Catch event on template/variable changing in custom plugin develop
I have a panel which has some variables, on changes of variable I want an event to get triggered
constructor($rootScope, $scope, $injector, $http, templateSrv) {
  $rootScope.onAppEvent('template-variable-value-updated', this.onVarChanged.bind(this), $scope);
onVarChanged() {
Used this did not work
What is the approach if the version is 6.6?
Is there a different approach for 5.4.2 ??
If it is different can I know for both the versions?
