I have setup a dashboard with multiple panels. Two of these panels have an alert, but only one of them is fired. The first panel is a query on a SQL Server, if this reaches a certain value an alert is raised and send to Slack and Pushover. This all works fine on this panel.
The second panel is checking if my service is running, using Promotheus and this query:
The channel is setup and the first panel is sending alerts to this. But thank you, I found a problem about the second panel in the log files.
I seen an error “Failed to upload alert panel image.”. I switched off the “Include image” in the notification channel setting, after that the alert for both panels are sent OK.
Is it not possible to send an image from a Promotheus datasource, or is this a problem in my “query”?
t=2019-12-12T10:29:29+0100 lvl=info msg=“Executing slack notification” logger=alerting.notifier.slack ruleId=0 notification=Slack
t=2019-12-12T10:29:58+0100 lvl=info msg=“Rendering timed out” logger=rendering
t=2019-12-12T10:29:58+0100 lvl=eror msg=“Failed to upload alert panel image.” logger=alerting.notifier error=“Timeout error. You can set timeout in seconds with &timeout url parameter”
t=2019-12-12T10:29:58+0100 lvl=eror msg=“Failed to send pushover notification” logger=alerting.notifier.pushover error=“context deadline exceeded” webhook=Pushover
t=2019-12-12T10:29:58+0100 lvl=eror msg=“failed to send notification” logger=alerting.notifier uid=gRnQ0-aZz error=“context deadline exceeded”
