Is it possible to display a value from several servers in a graph with a wildcard in the host entry?
I have 5 servers that are supposed to display a value as a bar chart. Normally I would do 5 queries - each with different server names. Is it also possible to do a query where all 5 servers are displayed?
Yes it’s possible, you can either change your query to bring all servers and then use Transform Tab to filter only for the 5 servers, or you can use wildcard in your query that matches your server names for example.
