I Would like to show only one country Ex. India on Map in grafana.
I tried using grafana-worldmap-panel-95f8956 plugin but i do not see any option to do so?
Is there any other plugin for showing only one country map? or is there any workaround?
Dear @userpkp,
will you be able to somehow add a filter constraint to your metrics query?
With kind regards,
Andreas.
Thanks for your response @ amotl
What kind of filter constraint to be added to the metrics query to show one country? Do you have some example or reference?
Dear @amotl
If you would have the country code within your metrics database, a simple WHERE country_code = "IN"
would do.
OK. Will give a try. So, If there is a filter with country_code = “IN” would only show India Map.
