NTLM Authentication not working
Does anyone facing any issue in NTLM Authentication?
The below code is not working -
{"GET", "http://domain\\username:password@example.com/"}})
ERROR - net/url: invalid userinfo at native
Hi @vishal.lanke,
Have you seen this example?
Also keep in mind that NTLM won’t work with HTTP/2.
@mostafa
Yes, I followed this example.
const username = 'user';
Ideally, this would be const username = 'domain\userName';
On Loadimpact blog, it has mentioned to use domain\\userName Double slash, instead of single.
I also tried that, but its not working
When I gave , I got error in response as {
When I use \, I got error as net/url: invalid userinfo at native
@vishal.lanke,
I’ve tested it, and apparently it’s a bug in handling username that contains a domain name. I’ve filed a report. Feel free to upvote:
@vishal.lanke can you try by replacing / with %2F as in username%2Fdomain
Thanks a lot for your help
Yes , sure
