I’m provisioning my dashboards from json-files, this way I can create dashboards in test and move them along through stage and prod. This works well.
Problem is, it seems that notifications that I set for alerts in graphs of the provisioned dashboards aren’t included during provisioning. If I could set them manually in a persistent manner I could probably live with it for now, but since the dashboards are provisioned I can’t save any changes.
The notification channels might differ slight between different environments as well. How would one handle this situation? Is it possible to solve?
Right now the only working solution is to stick with one notification channel and use it for all alerts, but that is really not good enough.
