What Grafana version and what operating system are you using? - 7.2.1
I was using below query to pull data based on POD memory Bytes for Kubernetes. There are nearly 200+ pods available in cluster
from(bucket: “telegraf”)
|> filter(fn: (r) => r["_measurement"] == “kubernetes_pod_container”)
|> filter(fn: (r) => r["_field"] == “memory_usage_bytes”)
|> filter(fn: (r) => r[“pod_name”] != “”)
|>keep(columns: ["_time","_value",“pod_name”])
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: false)
|> yield(name: “mean”)
but when run this query in grafana, it returns data for nearly 50 pods, however when running same query in chronograf, getting data for all 200+ pods. So is there any limitations in grafana to show limited records? what is the resolution to get data for all pods.
