Grafana v11.1.3 , Debian 12 bookworm on VMware ESXi -
Want to ingest the file and make it appear in the WebApp -
What happened?
I’m trying to host a local server for internal use which the server has no internet connection, all the binaries I downloaded from a local machine and transferred there to be installed:
- grafana-11.1.3.linux-amd64.tar.gz
- loki_3.0.1_amd64.deb
- promtail_3.0.1_amd64.deb
Then with sudo dpkg -i files.deb
and tar -zxvf file.tar.gz
Loki and Promtail is installed to /usr/bin/ and grafana just extracts into a folder and in grafana/bin contains the binary, which I used # > ./grafana server
I could acces the website on localhost:3000 and navigate around. Using Loki as a data source and save & test was successful.
Configuration wise also able to fetch the log file inside the path but nothing pops up. I ran this on my VM and everything was okay. The only difference is the internet access factor.
I expect the varlogs label to be appeared in the WebApp -
/etc/loki/config.yml:
auth_enabled: false
server:
http_listen_port: 3100
grpc_listen_port: 9096
common:
instance_addr: 127.0.0.1
path_prefix: /tmp/loki
storage:
filesystem:
chunks_directory: /tmp/loki/chunks
rules_directory: /tmp/loki/rules
replication_factor: 1
ring:
kvstore:
store: inmemory
query_range:
results_cache:
cache:
embedded_cache:
enabled: true
max_size_mb: 100
schema_config:
configs:
store: tsdb
object_store: filesystem
schema: v13
index:
prefix: index_
period: 24h
ruler:
alertmanager_url: http://localhost:9093
/etc/promtail/config.yml:
server:
http_listen_port: 9080
grpc_listen_port: 0
positions:
filename: /tmp/positions.yaml
clients:
- url: http://localhost:3100/loki/api/v1/push
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
__path__: /var/log/grafana/ingest/*log
localhost:3000/api/health returned okay
localhost:3100/ready returned ready
localhost:9080:
file_watch_config:
min_poll_frequency: 250ms
max_poll_frequency: 250ms
server:
http_listen_network: tcp
http_listen_address: ""
http_listen_conn_limit: 0
grpc_listen_network: tcp
grpc_listen_address: ""
grpc_listen_port: 0
grpc_listen_conn_limit: 0
tls_cipher_suites: ""
tls_min_version: ""
http_tls_config:
cert: ""
key: null
client_ca: ""
cert_file: ""
key_file: ""
client_auth_type: ""
client_ca_file: ""
grpc_tls_config:
cert: ""
key: null
client_ca: ""
cert_file: ""
key_file: ""
client_ca_file: ""
register_instrumentation: true
report_grpc_codes_in_instrumentation_label_enabled: false
graceful_shutdown_timeout: 30s
http_server_read_timeout: 30s
http_server_read_header_timeout: 0s
http_server_write_timeout: 30s
http_server_idle_timeout: 2m0s
http_log_closed_connections_without_response_enabled: false
grpc_server_max_recv_msg_size: 4194304
grpc_server_max_send_msg_size: 4194304
grpc_server_max_concurrent_streams: 100
grpc_server_max_connection_idle: 2562047h47m16.854775807s
grpc_server_max_connection_age: 2562047h47m16.854775807s
grpc_server_max_connection_age_grace: 2562047h47m16.854775807s
grpc_server_keepalive_time: 2h0m0s
grpc_server_keepalive_timeout: 20s
grpc_server_min_time_between_pings: 5m0s
grpc_server_ping_without_stream_allowed: false
grpc_server_num_workers: 0
log_format: logfmt
log_level: debug
log_source_ips_enabled: false
log_source_ips_header: ""
log_source_ips_regex: ""
log_request_headers: false
log_request_at_info_level_enabled: false
log_request_exclude_headers_list: ""
http_path_prefix: ""
external_url: ""
health_check_target: null
disable: false
profiling_enabled: false
enable_runtime_reload: false
client:
url: ""
batchwait: 1s
batchsize: 1048576
follow_redirects: false
enable_http2: false
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
drop_rate_limited_batches: false
clients:
batchwait: 1s
batchsize: 1048576
follow_redirects: true
enable_http2: true
backoff_config:
min_period: 500ms
max_period: 5m0s
max_retries: 10
timeout: 10s
tenant_id: ""
positions:
sync_period: 10s
ignore_invalid_yaml: false
scrape_configs:
- job_name: system
static_configs:
- targets:
- localhost
labels:
job: varlogs
target_config:
sync_period: 10s
stdin: false
limits_config:
readline_rate: 10000
readline_burst: 10000
readline_rate_drop: true
max_streams: 0
max_line_size: 0B
max_line_size_truncate: false
tracing:
enabled: true
profiling_enabled: true
wal:
enabled: false
dir: ""
cleanSegmentsOlderThan: 0s
watchConfig:
minReadFrequency: 0s
maxReadFrequency: 0s```
Sytem (1/1) ready with `discovered labels` and `target labels` correctly mentioned.
Is there any problem with the grafana server binary in this case?
* Did you follow any online instructions? If so, what is the URL?
https://grafana.com/docs/loki/latest/operations/troubleshooting/
