I’ve been importing data from SQL17 to create graphs. The SQL data sets are being constantly updated by the machines they are recording. My issue comes when I try to change the time frame of the data set. We know that the data is populated at these times but it still will not show or only shows a small portion of the data. For example, If I select to show last 6 hrs, the graph will scale to 6 hrs but data will only appear over the 5th hr of that time frame while all that data appears when I chose “last 12 hrs” or “last 24 hrs”
I’m seeing something similar - I have weeks of data on a certain set of metrics. “Last 2 days” works fine in my dashboard, but when I go beyond that, some of the data (but not all) vanishes.
