as there are no packages or docker images für i386 platform I am building my own grafana docker images for almost two years to use grafana on an old 32bit-only system.
Since version 6.6.0 grafana uses the cypress.io package and the builds for i386 are failing with
URL: https://download.cypress.io/desktop/3.7.0?platform=linux&arch=ia32
Error: Failed downloading the Cypress binary.
Response code: 404
Response message: Not Found
The command '/bin/sh -c yarn install --pure-lockfile' returned a non-zero code: 1
build hook failed! (1)
cypress.io doesn’t support 32bit on Linux systems as their website claims.
Is there a way to build grafana without cypress or is version 6.5.3 really the last version which supports i386 systems?
Thomas
