Newbie Question
Hi There,
im pretty new to grafana. I have an openhab system with mysql as persistence layer.
Is it possible to display something like this in grafana (e.g with table plugin) ?
2018-11-16%2013_43_37-Window
You may be interested in this topic on the openHAB community forum: https://community.openhab.org/t/influxdb-grafana-persistence-and-graphing/13761
Grafana is very flexible, you can probably come up with many ways to get your data on a dashboard.
There is a generic MySQL plugin if you want to tap directly into your openHAB database:
http://docs.grafana.org/features/datasources/mysql/
And there are several panels which can help you build a table similar to this.
Thanks for your help. I will try those panels.
