Question / Issue: Trying to use chained-variables as Datasource(s) in a repeating Panel or Row.
Context: I have 2 variables:
$site
: Custom var with a number of sites.
$site_prometheus
: Datasource variable, that should be “chained” to $site
The goal is to have a repeating Panel or Row, that repeates over $site
and updated $site_prometheus
$site
$site_prometheus
How & What are you trying to achieve?
To create a repeating panel over $site
, that chained-variable $site_prometheus
updated accordingly. Like so:
What happened?
But it’s not working as expected. The$site_prometheus
will not change based on $site. Instead it stays the same, on all panels. -
I expected that each repeating panel’s$site
→ will update the$site_prometheus
. As a chained-variables.
Anything obvious that I’m doing wrong?
