Hi Team,
We are using Grafana alerting feature to send events to ServiceNow using webhooks. Here we have a requirement to send IP address to ServiceNow.
I am trying to extract IP address from instance variable ( instance=“10.163.133.80:9090”) . Tried with below options in annotation fields, but no luck.
{{ printf "Instance %s is down" (reReplaceAll :[0-9]+
.Labels.instance ``) }}
{{ reReplaceAll “:[0-9]+” .Labels.instance “” }}
I appreciate any help/guidance you can provide
Regard,
Jijo
Hey @jijomilestogo
What happen with your actual templates? What’s the output?
Hello @codi639 ,
I am getting output as below. node and summary is not showing. We are not using templates here, we are parsing the json payload from Grafana in ServiceNow
Thanks,
Jijo
What I call template is something like {{ reReplaceAll ":[0-9]+" .Labels.instance "" }}
, my bad haha.
Would it be a bad thing if the IP show directly on the description?
Also, I just saw that you use the char ` for the node and the char " for the Summary, is there a reason?
Ohh ok , got it.
IP address can be on the description also, its fine , but i need to removed the port :9090 before displaying it
I was just trying with multiple options
Regards,
Jijo
Then, in your summary, can you try to slightly change your private ip part to {{ regexReplaceAll ":[0-9]+" .Labels.instance "" }}
or {{ regexReplaceAll ":.*" .Labels.instance "" }}
Let me know how it goes.
sure let me try with above
