ravish
1
I have Apache server and following two type of request (HTTP) is passing into it:
- get-list request
2, download request
I want to create a dashboard, on which i can reflect following use cases:
- "how many success/fail/Repeating request in the system ( the date could be selected ) ".
- how many/which IP keep sending repeating request ( include the download url, files size and so on ) to the platform.
Will the above kind of dashboard motioning solution be implemented using Grafana?
Are you using a collector to save the data about Apache to a time series database?
There are a couple of dashboards for Apache on Grafana.com - https://grafana.com/dashboards?search=apache but if you can use those depends on the collector and database that you are using.
ravish
3
currently, i am in analysis phase of the dashboard. I am thinking how can i implement my dashboard using grafana.
for now, i have no idea how to design.
are you suggesting to save the data about apache in a DB first? Will oracle DB be suitable?
following question:
- request and response are logging into apache server. shall i write a script to read logs and then populate the data base?
- what you meaning by "collector "?
Please help.
