I am using graphite-1.1.X version, the problem is I am using pipe(|) symbol in metrics so grafana is not populating any value in the graph.
I have asked the graphite community they told like from grafana 1.0.X they are using pip as a reserved symbol. they are using in a target for some other purpose and they told me to use an escape character with the pipe symbol.
The problem here is $brick_path is a template variable, if it is static metrics then i can give escape character like “|” or something but here I am using an as dynamic variable. Whatever query is written for $brick_path will populate values.
So is there any way to replace | into \| in grafana or how to solve this problem. please suggest me some solution.
