9.0.2 -
Maintained the Kyosk mode while navigating through dashboards. -
This dashboard is embedded in my product. The iFrame URL already contains the kyosk mode included, so when the dasboard is called, it appears to users as it should be.
Problem is, when users navigate through different dashboards, the kyosk mode is disabled and the dashboards display the side menu and the other icons. -
What happened?
Explained above. -
I expect the other dashboards to also maintain the Kyosk mode. -
Can’t copy. -
No logs for this. -
No instructions followed.
Any help is well received.
