I can use some help with MySQL data in Grafana. I have a table that contains stock and the date goes from 2007-01-02 to 2007-03-15. But when I select the last six months it returns 2007-01-02 to 2007-03-14 (note I don’t have this problem when the data is stored in Google Sheets? Thanks for your time.
What happened?
