Multiple binary sensors in a single dashboard
    Grafana 9.1.2 on HomeAssistant 2024.1.2
    Combining multiple binary (on/off) sensors, and also some floating values in a single graph.
    The sensors are from a heatpump, are closely related and are best interpreted in a single graph.
    Using the build in dashboard builder.
    The attached image gives an indication how I think it could be.
    problems with?
  • I don’t know where to look for relevant (multiple binary sensor) examples.
can you add multiple queries?
Yes I can.
