I have a dashboard with variables displayed inside a Controls menu.
One of the variables is a multi-select variable (sensor_channel). The selected values are displayed as tags with an × icon.
Issue:
Clicking the × icon on a selected value inside the Controls menu does not remove or deselect the value.
The variable selection remains unchanged.
Expected behavior:
- Clicking the × icon should remove the selected value from the multi-select variable.
Comparison:
For variables displayed outside the Controls menu, clicking the × icon works correctly and the value is deselected.
The problem only occurs for the variable shown inside the Controls menu.
Has anyone encountered this issue? Is this a known bug or expected behavior?
Grafana Version: 13 >
Thanks.
