Multi bar panel shows unsigned .How to use signed version?
Hi @anupa - is this the Multibar plugin you’re referring to? https://github.com/CorpGlory/grafana-multibar-graph-panel
If so - that’s a community-built plugin that has not been updated to support more recent versions of Grafana. The author is not actively developing anymore and suggests that you use https://github.com/chartwerk/grafana-chartwerk-app per README.md
