Move\Migrate Grafana
Hi, I want to migrate a grafana installation (v 5.3.4) to a new server.
Is there a guide\docs or best practices to move grafana (without losing data,plugins, configurations, dashboard, datasource, …) from an old server to a newer?
Old Server OS: Ubuntu 16.04
New Server OS: Debian 9.6.0
Thanks !
I didn’t find any good doc about it.
I only find this: http://docs.grafana.org/installation/upgrading/#database-backup
Maybe this topic might help you:
https://community.grafana.com/t/backup-restore-grafana-server/121
If it does not work let us know again.
ok. thx.
I will carry out the migration and give feedback.
bye
Hi, it works.
Step:
  1. Install new instance of Grafana
  2. Install used plugin on new server
  3. Stop Grafana service on source and destination server
  4. Copy /var/lib/grafana/grafana.db from old to new server
  5. Check /etc/grafana/grafana.ini
  6. Restart Grafana
  7. Regular connection to the grafana url
  8. Dashboard, datasource, users, psw, team,… are the same
Great !
thanks. bye.
Just wanted to say that it’s still working in 2021 with grafana 8.x!
I can confirm. Just upgrade from 7.3.3 to 8.0.1 without issues this way!
What about Grafana license.Will it work ?
Er, what licence?
Grafana is licensed under GNU AGPL 3.
Antony.
I am using Grafana Enterprise.i want to move my grafana from current environment to a different Environment.
i just want to know the the license will work or not?
