Move dashboards from root folder
Using Grafana 11.5.1.
When we started using Grafana, we did not think too much about organisation of dashboards, so a lot of them are stored in the root folder in the dashboards dashboard. Now I would like to tidy up a bit. For dashboards in a subfolder, I can click the name of the subfolder and then I get a checkbox at each dashboard and I can check them to move or delete. BUt for dashboards in the root folder, I cannot find that function. The only way I can see to move a dashboard would be to save a copy, but then the link will be changed for access from outside Grafana.
Have I overlooked something?
This is what I want to get for dashboards in the root folder, I got here by clicking the Array folder name
Ouch, Found a way, through the Settings menu on the dashboard, although that means I have to move them one by one.
