More alerting confusion: labels disappear after look-back period
This is a similar issue to so many posted here in the past, not sure if identical and just a restating or novel problem.
Dead-man alerts. Node down, as measured by lack of data for a series. Once the look-back period for the search reaches the end of the data that caused the alert, the labels on the alert disappear (because the labels are attached to the missing data).
In the past, I’ve used Kapacitor to alert from Influx DB. Kapacitor creates a matrix in memory of the measurement and labels for each alert rule, and the alert continues to sound, with appropriate labels attached, long after the data has stopped flowing, until Kapacitor is restarted and loses it’s state records.
In Grafana, there are no state records.
For example, if CPU percent used series stops flowing for a host for 5 minutes, looking back 10 minutes, a new alert is generated. That alert contains the hostname, and all other labels associated with the host. But once the host has been down 10 minutes, the labels all disappear, and this appears to our ticketing service as a new, blank, alert. From “hostnameABC, East, PROD, database server is down” to “blank, blank, blank, blank is down”.
Where is state stored in Grafana alerting? Or doesn’t it? How do I scale this to thousands of hosts if there’s no state data? Or do I just need a different alerting engine?
Ah, this might be resolved: from Grafanacon:
Troubleshoot alerts with ‘Keep last state’
We are happy to (re)introduce the Keep last state feature to Grafana-managed alert rules.
A popular feature from legacy alerting, this functionality helps maintain and manage alerts when query responses or data sources are flaky. You can now choose to keep the last evaluated state of an alert rule when that rule produces No Data or Error results. Simply choose the Keep last state option for no data or error handling when editing a rule.
Refer to the Grafana Alerting documentation on state and health of alert rules for more information.
