Monitor IBM Server
We have an IBM Server (AS/400). Yes, they still exist. IBM uses DB2 as it’s database. I have written a number of queries that check different system information (e.g. Number of active jobs running, current memory available/used by jobs, etc). On the IBM, all of this information is dynamically stored in tables in the native DB2 database. Therefore, setting up a dashboard for server stats is as easy as querying the DB2 database. However, I’m not sure if there’s an support for this. Has anyone else had the same issue and came up with a solution?
Thanks
