Grafana v12.0.2 -
Using Grafana HTTP API to update a dashboard’s permissions when the dashboard is part of an org that is not the default org. -
POST to create dashboard
send: b’POST /apis/dashboard.grafana.app/v1beta1/namespaces/org-196/dashboards HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept:/\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\nContent-Length: 8967\r\n\r\n’
send: b’{“metadata”: {“name”: “redacted”} …
reply: ‘HTTP/1.1 201 Created\r\n’POST to modify permissions of dashboard
send: b’POST /api/dashboards/uid//permissions?orgId=196HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept:/\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\nContent-Length: 48\r\n\r\n’
send: b’{“items”: [{“role”: “Viewer”, “permission”: 1}]}’
reply: ‘HTTP/1.1 400 Bad Request\r\n’GET just returns [ ]
send: b’GET /apis/dashboard.grafana.app/v1beta1/namespaces/org-196/dashboards HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept:/\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\n\r\n’
reply: ‘HTTP/1.1 200 OK\r\n’ -
What happened?
400 Bad Request -
The permissions would be applied to the dashboard -
The post requests were provided above -
No errors that I observed -
Dashboard HTTP API | Grafana documentation
Dashboard Permissions HTTP API | Grafana documentationThank you!
I have also tried the following POST as well via the RBAC API based on what the web UI uses but it fails as well though the GET works.
send: b’POST /api/access-control/dashboards/redacted/builtInRoles/Viewer HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept: /\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\nx-grafana-org-id: 196\r\nContent-Length: 21\r\n\r\n’
send: b’{“permission”:“View”}’
send: b’GET /api/access-control/dashboards/redacted HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept: /\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\nx-grafana-org-id: 196\r\n\r\n’
[{‘id’: 0, ‘roleName’: ‘’, ‘isManaged’: False, ‘isInherited’: False, ‘isServiceAccount’: False, ‘builtInRole’: ‘Admin’, ‘actions’: [‘annotations:write’, ‘annotations:delete’, ‘annotations:create’, ‘dashboards.permissions:read’, ‘dashboards:write’, ‘dashboards:delete’, ‘dashboards.permissions:write’, ‘dashboards:read’, ‘annotations:read’], ‘permission’: ‘Admin’}]
It’s solved by adding content-type application/json header
send: b’POST /api/dashboards/uid/redacted/permissions HTTP/1.1\r\nHost: redacted\r\nUser-Agent: python-requests/2.29.0\r\nAccept-Encoding: gzip, deflate, br\r\nAccept: /\r\nConnection: keep-alive\r\nAuthorization: Bearer redacted\r\nContent-Type: application/json\r\nx-grafana-org-id: 196\r\nContent-Length: 48\r\n\r\n’
