Modify configuration appears: Unexpected error
grafana-server -v
Version 8.4.3 (commit: b7d2911cac, branch: HEAD)
grafana-cli -v
Grafana CLI version 8.4.3
My Grafana config is
[server]
protocol = http
domain = zysy-warning
root_url = http://zysy-warning
serve_from_sub_path = true
router_logging = true
When my IP is: 172.16.10.131
Grafana IP is: 172.16.10.130
I modified the configuration through the web page and everything went well.
BUT:
When my IP is 10.5.4.10
An error occurs when you modify the configuration: Unexpected error
Web console: TypeError: NetworkError when attempting to fetch resource.
Browser: Firefox 98.0.1
click: Save & test (The same error occurs when you change your password.)
I considered the possibility of a cross-domain error
When I tried to use nginx for reverse acting, there was still a mistake.
But mistakes were made.
This error is not seen in /var/log/grafane/grafana.log
How should I configure it?
try using this for root_url:
root_url = %(protocol)s://%(domain)s:%(http_port)s/grafana/
