Version 8.4.5 running in Kubernetes from Docker image by helm chart:
resource "helm_release" "this" {
name = "kube-prometheus-stack"
repository = "https://prometheus-community.github.io/helm-charts"
chart = "kube-prometheus-stack"
version = var.kube_prometheus_stack_chart_version
namespace = kubernetes_namespace.this.metadata.0.name
Display top 5 max values for Sonarqube projects metrics (task duration) -
Using query editor, got an expression:
"max_over_time((rate(sonarqube_compute_engine_tasks_running_duration_seconds_sum{project_key=~\".*\"}[2h]) * 1 / rate(sonarqube_compute_engine_tasks_running_duration_seconds_count{project_key=~\".*\"}[2h])[{$__range}s]))"
What happened?
"bad_data: 1:202: parse error: missing unit character in duration"
resulted -
Expected to see values displayed -
See above -
No
