Missing fields in wildcard search
    Grafana v9.4.1 (fd67ab151d)
    Do a wildcard search and get all fields of my sensor data.
    SELECT * FROM $table WHERE $timeFilter
  • What happened?
    Result only displayed one field.
    Display all fields
    No
    When I search “confidence” (one of my fields) I get the right result.
    When I search “start” (another field) I get the right result.
    When I use a wildcard, I only get one field (called assetId).
Last week I was getting all fields displayed. Starting 02/24/2023, I only saw a single field.
How can I display all fields in a query?
