Minimum MySQL privileges required for Grafana's internal database user
Hi Grafana community,
I’m migrating our Grafana setup from using the MySQL master user to a dedicated application user with limited privileges, and I need help determining the minimum required MySQL permissions.
Current setup:
  • Grafana latest version
  • Aurora MySQL 8.0 (AWS)
  • Currently using master user (too permissive)
  • Want to switch to a dedicated user with minimal but sufficient privileges
My question: What are the minimum MySQL privileges needed for Grafana
I would guess to venture it would need your basic CRUD permissions for starters.
So when spinning up MySQL server, it might require table creation for permissions to scaffold everything.
