Hi @infofcc3 here what I’ve done.
My starting point is Smokeping that, for google dns 8.8.4.4, gives an average around 15.9 ms
STEP 1
Original systemd service from Manjaro package in /usr/lib/systemd/system/prometheus-smokeping-prober.service
[Unit]
Description=Prometheus style smokeping
After=network-online.target
Wants=network-online.target
[Service]
ExecStart=/usr/bin/prometheus-smokeping-prober --config.file="/etc/prometheus/smokeping_prober.yml"
ExecReload=/bin/kill -HUP $MAINPID
DynamicUser=true
NoNewPrivileges=true
ProtectSystem=full
ProtectKernelModules=true
ProtectKernelTunables=true
PrivateTmp=true
LockPersonality=true
ProtectHostname=true
ProtectHome=true
ProtectControlGroups=true
ProtectKernelLogs=true
PrivateDevices=true
RestrictRealtime=true
CapabilityBoundingSet=
MemoryDenyWriteExecute=true
CapabilityBoundingSet=CAP_NET_RAW
AmbientCapabilities=CAP_NET_RAW
[Install]
WantedBy=multi-user.target
Not sure if –privileged is needed
My configuration file in /etc/prometheus/smokeping_prober.yml contains
targets:
- hosts:
- cloudflare-dns
- google-dns
- nexxt-int
- p9-principale-ext
- mostro
- kit-studio
- bianco500
interval: 1s # Duration, Default 1s.
network: ip # One of ip, ip4, ip6. Default: ip (automatic IPv4/IPv6)
protocol: icmp # One of icmp, udp. Default: icmp (Requires privileged operation)
size: 56 # Packet data size in bytes. Default 56 (Range: 24 - 65535)
Originally there were another two lines in this file that I had to remove in order to access the prober from the 192.168.1.0 lan
source: 127.0.1.1 # Souce IP address to use. Default: None (automatic selection)
tos: 0x00 # Packet ToS field in decimal, hexadecimal or binary format. Default: 0 (Range: 0-255)
To use only names for the targets without relaying on DNS I have in /etc/hosts (the VM I’m using have “netmon-vm” hostname)
# Standard host addresses
127.0.0.1 localhost
::1 localhost ip6-localhost ip6-loopback
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
# This host address
127.0.1.1 netmon-vm
1.1.1.1 cloudflare-dns
8.8.4.4 google-dns
192.168.1.254 nexxt-int
192.168.1.50 p9-principale-ext
192.168.1.10 mostro
192.168.1.40 kit-studio
192.168.68.30 bianco500
With these settings I can access the probe metrics
The curl command for the “google-dns” host gives
[mirto@netmon-vm ~]$ curl -s http://netmon-vm:9374/metrics | grep google-dns
smokeping_requests_total{host="google-dns",ip="8.8.4.4",source="",tos="0"} 325924
smokeping_response_duplicates_total{host="google-dns",ip="8.8.4.4",source="",tos="0"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="5e-05"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0001"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0002"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0004"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0008"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0016"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0032"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0064"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0128"} 0
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0256"} 319266
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.0512"} 320651
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.1024"} 321685
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.2048"} 324263
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.4096"} 324315
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="0.8192"} 324377
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="1.6384"} 324379
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="3.2768"} 324379
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="6.5536"} 324379
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="13.1072"} 324379
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="26.2144"} 324379
smokeping_response_duration_seconds_bucket{host="google-dns",ip="8.8.4.4",source="",tos="0",le="+Inf"} 324379
smokeping_response_duration_seconds_sum{host="google-dns",ip="8.8.4.4",source="",tos="0"} 5782.676779012143
smokeping_response_duration_seconds_count{host="google-dns",ip="8.8.4.4",source="",tos="0"} 324379
smokeping_response_ttl{host="google-dns",ip="8.8.4.4",source="",tos="0"} 116
smokeping_send_errors_total{host="google-dns",ip="8.8.4.4",source="",tos="0"} 0
So it seems that it is gathering the metrics
STEP 2
The prometheus configuration file is /etc/prometheus/prometheus.yml to which I added the smokeping job
# my global config
global:
scrape_interval: 15s # Set the scrape interval to every 15 seconds. Default is every 1 minute.
evaluation_interval: 15s # Evaluate rules every 15 seconds. The default is every 1 minute.
# scrape_timeout is set to the global default (10s).
# Alertmanager configuration
alerting:
alertmanagers:
- static_configs:
- targets:
# - alertmanager:9093
# Load rules once and periodically evaluate them according to the global 'evaluation_interval'.
rule_files:
# - "first_rules.yml"
# - "second_rules.yml"
# A scrape configuration containing exactly one endpoint to scrape:
# Here it's Prometheus itself.
scrape_configs:
# The job name is added as a label `job=<job_name>` to any timeseries scraped from this config.
- job_name: "prometheus"
# metrics_path defaults to '/metrics'
# scheme defaults to 'http'.
static_configs:
- targets: ["localhost:9090"]
# The label name is added as a label `label_name=<label_value>` to any timeseries scraped from this config.
labels:
app: "prometheus"
- job_name: smokeping
static_configs:
- targets: ["localhost:9374"]
The query url
http://netmon-vm:9090/query?g0.expr=smokeping_response_duration_seconds_bucket+%7Bhost%3D%22google-dns%22%7D&g0.show_tree=0&g0.tab=table&g0.range_input=1h&g0.res_type=auto&g0.res_density=medium&g0.display_mode=lines&g0.show_exemplars=0
shows
That seems to have gathered the correct data
STEP 3
To start form a simple case, I’ll try to replicate the “Response time by bucket” panel
From Drilldown > Metrics > All metrics I select the proposed “smokeping_response_duration_seconds_bucket” example panel And added it to an empty dashboard
The default panel generated is this
Setting the Unit to “Seconds” and adding a filter for “google-dns” I obtain
According to the original dashboard I changed the query options
Obtaining something similar to the original dashboard panel
Remarks
In the original panel the query is (I don’t understand why the formula is multiplied by 2)
sum by (le) (
rate(smokeping_response_duration_seconds_bucket{host="${hostname:raw}",ip="${host:raw}",job="$job"} [$__interval])
) * 2
In my panel the query is
sum by(le) (rate(smokeping_response_duration_seconds_bucket{host="google-dns"}[$__rate_interval]))
What is the difference between $__interval and $__rate_interval ?
In the original panel the “values” correspond to the scale on the left but gives only one value
In my panel seems that the values follow the scale on the left but give an interval bucket value (is this correct?)
What is the difference between Value and Bucket?
And this is for a single host.
But if I want to monitor multiple hosts as in smokeping I don’t know how to do this.
In my understanding the heatmap cannot show multiple time series. Is this correct?
Any hint on how to proceed?
