Metrics from Elasticsearch don't match metrics from Azure
Team I’m jus configuring network traffic in and out in Grafana for linux server, my data source is Elasticsearch. after configuring, my concern to validate this with azure metrics. but its not matching at all.
my grafana part configuration
Elastic search field:
field is system.network.in.bytes, system.network.out.bytes (elastic search field). aggregation is sum.
Azure metrics :
Metrics name is Network In Total, Network Out Total, aggregation sum(avg also not compatible)
whenever I’m comparing the data with azure its doesn’t match and the unit also getting different (Mb to Gb). so kindly guide me In which metrics on azure which I have to look or compatible with elastic search to see network inbound and network outbound traffic to configure the same in grafana.
