I’m trying to trigger an alarm if A is higher than 300 or B is higher than 200. Both are data series.
For each $A > 300 and $B > 200 respectively I get the expected results, as you can see in the screenshot:
When I try to match either case like this:
($A > 300) || ($B > 200)
I get no data. I also tried without brackets, just to make sure, and it doesn’t any. Any ideas how I can solve this?
