MariaDB MySQL querey
Hi
I am trying to get Grafrana to graph my SQL data which is very simple but I am struggling with the following error
This is the Query
SELECT
UNIX_TIMESTAMP(time_stamp) as time_sec,
calls as value,
FROM active_calls
WHERE $__timeFilter(time_stamp)
ORDER BY <time_stamp> ASC
this is the error
Error 1064: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near ‘FROM active_calls
WHERE time_stamp >= FROM_UNIXTIME(1500850800) AND time_stamp <’ at line 4
My MySQL data structure is very simple, see attached from active_calls table
Any ideas how to get this working?
You can < and > signs in your query replace them with the right column name
