Mainframe TMON CISC & TMON MVS monitoring feasibility
Need to know the feasibility to monitor the Mainframe TMON CISC & TMON MVS using Grafana plugins or using Prometheus? I could not find much info on doc on these technologies hence posting a topic.
I couldn’t find an official Grafana plugin or Prometheus exporter specifically for TMON for CICS or TMON for MVS.
Feasibility depends on how your TMON versions expose their data:
Data extraction → Check with Rocket Software which APIs, exports, or other data access methods your TMON versions support.
Prometheus → If the data can be accessed programmatically, a custom exporter can expose selected metrics in Prometheus format for Grafana.
Alternatives → If TMON data is available over an HTTP API returning JSON, the Infinity data source can query it directly. If you only get batch or file extracts, load them into a database such as PostgreSQL or InfluxDB and query that from Grafana.
IBM SMF records may also provide some CICS or z/OS performance data, but they’re not a direct substitute for TMON metrics.
Hi @prashanthan1987 just wanted to check if you got the solution . Happy to help further if you are facing any issues .
