Lookup xxxx:no such host error on MSSQL datasource save
I am not able to add MS SQL datasource to grafana server.
Receiving “lookup xxxx:no such host error”.
I am able to connect to the SQL server from the Grafana server using same connection string via sqlcmd.
Error in Grafana log is following:
lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=POST path=/api/tsdb/query status=400 remote_addr=xxxxxx time_ms=53 size=251 referer=https://xxxxxxx/datasources/edit/56/
Grafana version 7.0.3
MSSQL version 2019 Enterprise
Please advice
Is “xxxx” (or “xxxxxx”) a hostname or an IP address?
If it’s a hostname, does it resolve to the correct IP address if you use one
of the following commands on the Grafana server:
host xxxxxx
ping -c 1 xxxxxx
nslookup xxxxxx
If it’s an IP address, what do you get from:
ping -c5 xxxxxx
traceroute xxxxxx
Regards,
Antony.
Thank you Antony,
xxxx is FQDN of the server.
and is resolved to correct IP when host xxxx is called
host field is: {FQDN of the SQL server},{not standard port}
my mistake was to put “,” - comma between servername and the port, instead of putting “:” - colon
I think this is a nice illustration of how helpful it can be to specify
exactly what you’ve entered, as well as exactly what the result is, when
asking for assistance :slight_smile:
The format you used was not clear from your original posting…
Antony.
