My setup:
Docker setup with a grafana 9.1.6 container and InfluxDB container as data source
What am I trying to achieve:
I have a signal that reports the status of a system, and a signal that reports an error or warning that this system reports if something is not correct.
I have a dashboard with a table panel listing all the errors/warnings that were reported in the last X time. But they are displayed as a number or a string which is less readable than the description of the signal itself.
What I want is to have a look-up table, as exists in excel/sheets.
Now, I know I can use overrides. and I can override the values. Its easy when there are only a few possible values (such as system status). But with the errors I might have about 200-300 options, or even more in the future.
I can generate a Panel JSON code that has all these options, so I don’t have to do it manually.
Is it the optimal way?
I saw that there is an alpha version of a transformation named “Field Lookup” but for the version I have its use is not very self explanatory and is based on the field name and not on the value.
