Need help, i’m having an issue with promql max concurrency: unable to find decription how to count promql max concurrency
Didn’t find any mentions about this in docs
auth_enabled: true
schema_config:
configs:
store: boltdb-shipper
object_store: s3
schema: v11
index:
prefix: loki_index_
period: 24h
chunks:
prefix: loki_chunk_
period: 24h
storage_config:
aws:
bucketnames: loki-00,loki-01,loki-02,loki-03,loki-04,loki-05,loki-06,loki-07,loki-08,loki-09
endpoint: s3-host:7480
region: US
access_key_id: <id>
secret_access_key: <key>
insecure: true
sse_encryption: false
http_config:
idle_conn_timeout: 90s
response_header_timeout: 0s
insecure_skip_verify: true
s3forcepathstyle: true
boltdb_shipper:
shared_store: s3
active_index_directory: /var/lib/loki/boltdb-shipper-active
cache_location: /var/lib/loki/boltdb-shipper-cache
cache_ttl: 168h
resync_interval: 5m
query_ready_num_days: 2
index_cache_validity: 2h
max_chunk_batch_size: 100
index_queries_cache_config:
memcached:
expiration: 1h
batch_size: 100
parallelism: 100
memcached_client:
host: loki-cache.monitoring
service: index
consistent_hash: true
chunk_store_config:
max_look_back_period: 720h
cache_lookups_older_than: 1d
chunk_cache_config:
memcached:
expiration: 1h
batch_size: 100
parallelism: 100
memcached_client:
service: chunks
write_dedupe_cache_config:
memcached:
expiration: 1h
batch_size: 100
parallelism: 100
memcached_client:
service: dedupe
memberlist:
gossip_nodes: 2
randomize_node_name: false
abort_if_cluster_join_fails: true
bind_port: 7946
join_members:
- loki-gossip-ring.monitoring:7946
max_join_backoff: 1m
max_join_retries: 10
min_join_backoff: 1s
retransmit_factor: 3
gossip_to_dead_nodes_time: 15s
left_ingesters_timeout: 5s
dead_node_reclaim_time: 30s
server:
http_listen_port: 3100
grpc_listen_port: 9095
distributor:
ring:
kvstore:
store: memberlist
ingester:
chunk_block_size: 262144
chunk_target_size: 1536000
max_chunk_age: 3h
max_transfer_retries: 0
chunk_idle_period: 1h
chunk_retain_period: 5m
chunk_encoding: snappy
sync_period: 1m
sync_min_utilization: 0.7
lifecycler:
ring:
kvstore:
store: memberlist
replication_factor: 2
heartbeat_timeout: 1m
heartbeat_period: 5s
final_sleep: 0s
min_ready_duration: 10s
query_store_max_look_back_period: 0
wal:
enabled: true
dir: /var/lib/loki/wal
flush_on_shutdown: true
replay_memory_ceiling: 2GB
querier:
query_timeout: 15s
tail_max_duration: 15m
query_ingesters_within: 3h
query_range:
align_queries_with_step: true
max_retries: 3
split_queries_by_interval: 15m
parallelise_shardable_queries: true
cache_results: true
results_cache:
cache:
memcached:
expiration: 1h
memcached_client:
service: results
ingester_client:
grpc_client_config:
rate_limit: 30
rate_limit_burst: 50
max_recv_msg_size: 33554432 #1024 * 1024 * 32
remote_timeout: 15s
frontend_worker:
frontend_address: loki-querier-frontend.monitoring:9095
parallelism: 10
grpc_client_config:
rate_limit: 30
frontend:
log_queries_longer_than: 5s
compress_responses: true
tail_proxy_url: http://loki-querier.monitoring:3100
max_outstanding_per_tenant: 1024
table_manager:
retention_deletes_enabled: true
retention_period: 720h
poll_interval: 10m
creation_grace_period: 3h
limits_config:
ingestion_rate_strategy: global
reject_old_samples: true
reject_old_samples_max_age: 24h
ingestion_rate_mb: 30
ingestion_burst_size_mb: 50
max_query_length: 720h
max_streams_per_user: 0
max_global_streams_per_user: 100000 # 100k
# max_query_parallelism: 5
max_cache_freshness_per_query: 30m
enforce_metric_name: false
compactor:
working_directory: /var/lib/loki/boltdb-shipper-compactor
shared_store: s3
compaction_interval: 4h
tracing:
enabled: false
