Hi Loki team.
I’m using loki-distributed on AWS EKS, trying to test for migration between k8s clusters.
I thought that it could be done like what I attached.
But, even though throw /flush API to ingesters in old Loki, a query to new Loki doesn’t get logs that exist in old Loki.
Did I miss something?
Is there the best way to migrate between k8s clusters?
Thanks.
Could anyone please help me out?
I haven’t solved this issue yet.
I could migrate Loki as procedure below.
- Detach legacy Loki gateway from NLB Target.
- Delete legacy Loki gateway.
※detaching the gateway from NLB was not enough to kill the session from promtail to legacy Loki. - curl -X POST to all ingesters /flush endpoint.
- (After a few minutes after 3.) Delete all legacy Loki stack.
- Deploy new Loki to the new EKS cluster.
- Attach new Loki to NLB.
The procedure above should be done in 8.5 minutes or promtail drop after all retries.
※Or raise backoff_config.max_retries in promtail.
And I created bash below to do above.
#!/bin/bash
# Usage: sh loki_ingester_flush.sh <Name of Realese>
# e.g. sh loki_ingester_flush.sh multi-tenant
if [[ $1 =~ [a-z]+ ]]; then
echo "Current Context ----> `kubectl config current-context`"
echo "Helm Realese Name ----> $1"
read -p "Input 'yes' or 'y' key to start: " process
else
echo -e "helm realese name is required as argument\n e.g. 'sh loki_ingester_flush.sh multi-tenant'" ## -eオプションはエスケープ文字を解釈するという意味で、改行コードを解釈させるため
exit 1
fi
if [ $process == "yes" -o $process == "y" ]; then
INGESTER_POD_IP=`kubectl get po -l app.kubernetes.io/component=ingester,app.kubernetes.io/instance=${1} -n monitoring -o json | jq -r '.items[].status.podIP'`
kubectl delete deploy ${1}-loki-distributed-gateway -n monitoring
sleep 10
for ip in $INGESTER_POD_IP
do
echo "curl -X POST http://${ip}:3100/flush"
done
echo "sleep for 2min to flush chunk in the ingesters..."
sleep 120
echo "uninstall ${1} Loki stack"
helm uninstall $1 -n monitoring
else
echo "Goodbye!"
exit 1
fi
