Loki federation question
I have multiple EKS’s and I want to use Loki to get the logs into grafana. I know I can install a loki stack on each EKS but then in the grafana I would need to add x amount of datasources.
Is it possible to federate the loki queries so that I would have one datasource in grafana and the query would be sent to a specific loki instance based on labels or something else.
Thank in advance for the answers.
There is nothing to federate here. You would stand up one Loki cluster, and just send logs from all your EKS clusters to that one Loki cluster, using whatever log agent you like.
That is the conclusion I also got. I was just checking maybe I missed anything.
