Hello, I’m implementing the Grafana Loki in EKS cluster (AWS), I already install on HML environment and now I need to install on PRD.
The service is working as expected on PRD (the logs are available on Grafana Dashboard), but there are a error message that I need to discover the root cause.
The message " level=error ts=2023-01-11T19:24:39.35074857Z caller=table_manager.go:234 msg=“error syncing tables” err=“expected one sample stream for queue: 0” " is showed each 2 minutes. It don’t occours on HML.
Does anybody help me?
